Dusan Posted July 26, 2011 Share Posted July 26, 2011 Does anyone have a solution to problem with net framework when instaling max 2012? I've tried looking on forums but nobody seems to have the answer. Link to comment Share on other sites More sharing options...
datacrasher Posted July 26, 2011 Share Posted July 26, 2011 are you using any other 3ds max software or this is the first one your installing? are you using windows xp, visa, windows etc. Have you updated windows! If you go to the updates and patches on the autodesk website then you will see a new patch for the sevice pack and a hotfix (http://usa.autodesk.com/adsk/servlet/ps/dl/index?id=2334435&linkID=9241178&siteID=123112#section1 forum assistants don't delete) Link to comment Share on other sites More sharing options...
Dusan Posted July 27, 2011 Author Share Posted July 27, 2011 (edited) I have max 2010 and windows7. When instalation start I automatically get notification that net framework is not updated. I try updating it but I still get the same notification and after update max2010 won't work. Also updating windows doesn't help. Edited July 27, 2011 by Dusan Link to comment Share on other sites More sharing options...
datacrasher Posted July 27, 2011 Share Posted July 27, 2011 (edited) Duncan Can you give us a printscreen of the error message? i think i have seen the same on another fourm but i cannot be sure unless i see the error. from what i read it due to the OS being corrupted here is the link http://208.74.205.69/t5/Installation-Licensing/NET-FRAMEWORK-PROBLEM-3ds-Max-2012/td-p/3102310 Tony Edited July 27, 2011 by datacrasher Link to comment Share on other sites More sharing options...
Dusan Posted July 27, 2011 Author Share Posted July 27, 2011 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16436702&linkID=9241177 Tony this is the window that appears every time. I tried the solution they offered but didn't work. Link to comment Share on other sites More sharing options...
datacrasher Posted July 27, 2011 Share Posted July 27, 2011 if you followed my very last reply about the error then it should work, if not then i'll guess you have to contact your max sale and tech support dept where you brought your max because autodesk does not support products only the store you brought it from Good luck Tony Link to comment Share on other sites More sharing options...
Dusan Posted July 28, 2011 Author Share Posted July 28, 2011 OK Tony, thanks for help. I'll try contacting them. Link to comment Share on other sites More sharing options...
datacrasher Posted July 28, 2011 Share Posted July 28, 2011 You could always put this on the autodesk site and see what they say Good luck Tony Link to comment Share on other sites More sharing options...
theqball Posted July 29, 2011 Share Posted July 29, 2011 Try downloading an installing directly from MS. http://www.microsoft.com/download/en/details.aspx?id=17851 Sometimes this works better. Link to comment Share on other sites More sharing options...
Dusan Posted July 30, 2011 Author Share Posted July 30, 2011 Shane I tried installing directly from ms but didn't work. I'll try posting on autodesk website. Link to comment Share on other sites More sharing options...
theqball Posted August 3, 2011 Share Posted August 3, 2011 call support. reporting it to the autodesk website will either bounce it to my inbox or somewhere with limited visibility. other things to try are to uninstall all the .net frameworks on you machine and install the latest one from MS. this installer is better at catching the conflicts with older .net installs than the compressed one we ship with. You basically have a install conflict somewhere. Link to comment Share on other sites More sharing options...
