Max problem with imported CAD linework. Max really bogs.
danb4026
After I import linework (highrise, single elevation for example) into Max 2012, everthing really slows down. If I move the linework, it bogs. If I select the linework, it bogs.
Is this a problem with simply working with splines in the viewport or is it related to something having to do with the import?
PS....even worse, sometimes it just doesn't bog down, it crashes.
Edited by danb4026
max has a hard time dealing with too many 2D objects, you might want to slim down the imported file, delete whatever you don't need.
ya strip out what you don't need for modeling.
then import it in .
save as max.
open a blank file.
xref it in .
will save a lot on the slogishness of the file.
phil
