Cjmcphail Posted July 29, 2011 Share Posted July 29, 2011 Hi Guys, I’m finding myself wondering how the attached image was modelled, I found it in an architectural magazine. I appears to be some kind of fall off edit poly extrusion, I have tried to figure out how to replicate it but and all out of ideas. can anyone help? Link to comment Share on other sites More sharing options...
A.Mitov Posted July 29, 2011 Share Posted July 29, 2011 Looks like some type of script similar to "greeble" was used. Link to comment Share on other sites More sharing options...
Msamir Posted July 29, 2011 Share Posted July 29, 2011 I think its greeble with the plane subdivided into triangles Link to comment Share on other sites More sharing options...
Cjmcphail Posted July 29, 2011 Author Share Posted July 29, 2011 I agree on the triangles and the greeble, but its the way the extruded height seems to be less or "falls off" the further from the central height. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted July 30, 2011 Share Posted July 30, 2011 Second guess is that any of the pin screen tuts might shed some light. First guess was to use Design Reforms tuts like follows (mine is simplified from the target image): - make a single plane - instance it a lot - select all instances - apply an Affect Region for the height with falloff - apply a noise to shake it up - apply an Edit Poly and slap the Z button to level off each plane again - apply a Shell to thick them up Link to comment Share on other sites More sharing options...
Cjmcphail Posted July 31, 2011 Author Share Posted July 31, 2011 Second guess is that any of the pin screen tuts might shed some light. First guess was to use Design Reforms tuts like follows (mine is simplified from the target image): - make a single plane - instance it a lot - select all instances - apply an Affect Region for the height with falloff - apply a noise to shake it up - apply an Edit Poly and slap the Z button to level off each plane again - apply a Shell to thick them up I have done a few tests, and Im thinking that using this method with a bit of set up time is going to be the best way to get this effect Link to comment Share on other sites More sharing options...
Itoosoft Posted July 31, 2011 Share Posted July 31, 2011 (edited) Using two Forest Lite objects, applying a scale map on Z axis. You can adjust parametrically any parameter, animate it, etc. I've attached the scene for max 2010. Edited July 31, 2011 by Itoosoft Link to comment Share on other sites More sharing options...
Cjmcphail Posted August 5, 2011 Author Share Posted August 5, 2011 Using two Forest Lite objects, applying a scale map on Z axis. You can adjust parametrically any parameter, animate it, etc. I've attached the scene for max 2010. Thanks so much, This is a great Solution Link to comment Share on other sites More sharing options...
