Chris Potts Posted August 17, 2004 Share Posted August 17, 2004 Sorry, my english is not good explain about Class Curtain Wall in last topic, Igronce this one I got sort it out fix Glazing Curtian Wall, it alright now... Here my other question....( Im still learning 3D Viz ) Metal Cladding Wall, ( unfinish work project ) I know it look easy using material map repeat same size panel each across wall but problem is there have lots different size of panel joint together. Here, I have been done trying using draw line section then extrude to height then turn it into Editable Mesh using cut under 'Edge' rollout panel to cut across line each seperate panels each wall. When it done then Select Polying to extude back for windows. Then put in UV Mapping, tick 'Face' map on it. And I made material with single thin black edge around single square onto wall so It look good....... But some panel have across top right coner to bottom left coner, It not what I wanted... See 1st picture below...( I know one square equal 2 polyon face each that what cause it uvw face mapping )...I tried other option using material editior like blend, Mix, etc..it wont work... I couldnt figure it out and I have been check wireframe is clear have no line across middle of panel (See 2nd Picture)....Maybe I was mistake should not using cut line under Editable mesh tool. What else other way method? How it work one panel each without middle cross black line ???....... Link to comment Share on other sites More sharing options...
