redheadx Posted August 5, 2011 Share Posted August 5, 2011 Studio/Institution: redheadxGenre: Residential InteriorSoftware: 3ds max and VrayWebsite: http://redheadx.comDescription: This is a test rendering for a bathroom to use in my portfolio. As you can see I have not populated it yet. I'm just trying to nail down the light and materials first before adding more. Let me know what you think . Thanks Link to comment Share on other sites More sharing options...
AubreyM Posted August 5, 2011 Share Posted August 5, 2011 Lighting, textures and modelling are all solid. Different POV would be ok, not that the one you have is bad. Can't wait to see it finished. Link to comment Share on other sites More sharing options...
cmrodrigo Posted August 5, 2011 Share Posted August 5, 2011 you should work on materials and textures mix materials the scene is solid no feelings, modelling is a very important part when you are presenting and sitting down infront of the client it should be distinguish each and every details and how you put the lights in the scene. thanks good start.. good luck Link to comment Share on other sites More sharing options...
redheadx Posted August 6, 2011 Author Share Posted August 6, 2011 cmrodrigo said: you should work on materials and textures mix materials the scene is solid no feelings, modelling is a very important part when you are presenting and sitting down infront of the client it should be distinguish each and every details and how you put the lights in the scene. thanks good start.. good luck Thanks for your comment but I'm not following , could you be a little for specific Thanks Link to comment Share on other sites More sharing options...
redheadx Posted August 6, 2011 Author Share Posted August 6, 2011 Thanks Link to comment Share on other sites More sharing options...
kmanus Posted August 12, 2011 Share Posted August 12, 2011 It's small, since it is really only in the bottom right corner, but you might want to have the wood grain run horizontal on the top of the door, cabinets will most of the time have the grain running horizontal on the top and bottom of the cabinet door, and vertical on the sides (not talking about the inset panel part, but the frame around it), hard to explain, but just look at some pictures and you'll get it, you may want to have the grain run horizontal on the top drawers as well, but that is more a matter of taste... Link to comment Share on other sites More sharing options...
