zhopudey Posted August 5, 2011 Share Posted August 5, 2011 I have a scene with 8 buildings, which I have modeled separately and xref'ed. All buildings have the same color scheme. Now, if the architect wants to change the color, I have to do the change in 8 different files and then update my main file. Is there any way to ease this process? Link to comment Share on other sites More sharing options...
luthias42 Posted August 5, 2011 Share Posted August 5, 2011 create a material library that you can change in one file and then import into the others. You'll still have to open all the files, but at-least it'll just be a material swop instead of having to adjust them in every file. hopefully someone can come up with an idea that's faster and easier. Link to comment Share on other sites More sharing options...
cgrant3d Posted August 5, 2011 Share Posted August 5, 2011 You can also xref your materials. It'd take a bit to setup but works well. Only annoying thing is you don't have access to material parameters so you can't verify mat id's, mapping channels, etc except in your master material file. In any case - if you want to go this route I'd make a materials.max file with your materials on a bunch of spheres or something along those lines. Then using xref objects - reference those material spheres into each building file and apply those materials to your building. Note that you can skip the whole xref object step and do them one at a time by creating an "Xref Material" in the material editor but personally I find the xref object process more intuitive. Link to comment Share on other sites More sharing options...
zhopudey Posted August 6, 2011 Author Share Posted August 6, 2011 Ohh...xref'ed materials! I didn't know about that, thanks But I can't change materials on my xref'ed buildings, can I? That means I'll have to xref the materials into each building file and apply them there - and then xref the buildings into my final file. I'll have to create a "materials" max file for each project... Now how do I explain all this to everyone working under me?? Link to comment Share on other sites More sharing options...
sanmb Posted August 8, 2011 Share Posted August 8, 2011 try to merge as many files in one file change material and save it back. Link to comment Share on other sites More sharing options...
zhopudey Posted August 8, 2011 Author Share Posted August 8, 2011 try to merge as many files in one file change material and save it back. Then I wouldn't be using xref in the 1st place, would I? XRef materials seems to be the best option so far, just a little bit complicated... Link to comment Share on other sites More sharing options...
