A.Mitov Posted August 6, 2011 Share Posted August 6, 2011 (edited) Sometimes I stumble upon strange behavior in 3ds Max. Recently these problems appeared again on one of our computers and what's strange is that on another of our PCs we don't experience these problems. All PCs are identical - identical OS, Max versions, plug-ins and scripts installed. It's a large scale project - a football academy with big open spaces but not so big poly count - somewhere about 700 K polys. Sometimes when I Hit "M" to open Material editor Max just freezes and I have to terminate it in Task manager. Other times it just crashes to desktop when clicking "Save as..." without even showing the crash report screen. Now it even began crashing when hitting F9 without showing error report screen. So far we suspect the ColorCorrect plug-in by Cuneyt Ozdas ( http://www.cuneytozdas.com/software/3dsmax/ ) or V-Ray because when applying a "Standart" material to the whole scene we don't experience this unusual behavior (so far). Any help and ideas how to tackle this is greatly appreciated! Edited August 6, 2011 by A.Mitov Link to comment Share on other sites More sharing options...
datacrasher Posted August 6, 2011 Share Posted August 6, 2011 (edited) if you have 700k polys add optimize modifier to cut your polys down to half are you using the same amount of Ram on the same computers Alexander? what service pack are you using? try updating your max. it maybe the file your using. Restart max and start merging your objects into new scene make sure your using the same unit and system units. make sure you save as a new file name and not over-write the old file name once you have done this. You should delete the old file your usings If this does not work then it maybe the max.ini that has corrupted Tony Edited August 6, 2011 by datacrasher Link to comment Share on other sites More sharing options...
A.Mitov Posted August 8, 2011 Author Share Posted August 8, 2011 datacrasher said: if you have 700k polys add optimize modifier to cut your polys down to half are you using the same amount of Ram on the same computers Alexander? what service pack are you using? try updating your max. it maybe the file your using. Restart max and start merging your objects into new scene make sure your using the same unit and system units. make sure you save as a new file name and not over-write the old file name once you have done this. You should delete the old file your usings If this does not work then it maybe the max.ini that has corrupted Tony Both PCs have 16 Gigs of RAM. Max version is 2009 with the latest service pack and hotfixes. I've already tried merging all into a new scene but it didn't help. I may try your advice about the max.ini file. I hope this helps. Link to comment Share on other sites More sharing options...
sanmb Posted August 9, 2011 Share Posted August 9, 2011 Reinstalling Max is the better option. Link to comment Share on other sites More sharing options...
A.Mitov Posted August 9, 2011 Author Share Posted August 9, 2011 Removing the .ini file didn't help It seems I'll have to reinstall Max. Link to comment Share on other sites More sharing options...
A.Mitov Posted August 9, 2011 Author Share Posted August 9, 2011 (edited) Uninstalling didn't help either! Edited August 9, 2011 by A.Mitov Link to comment Share on other sites More sharing options...
datacrasher Posted August 9, 2011 Share Posted August 9, 2011 i have no idea then Alexander you have done all that we can suggest try the autodesk fourm and see what they say maybe they will have a better idea of what you can do. Link to comment Share on other sites More sharing options...
A.Mitov Posted August 9, 2011 Author Share Posted August 9, 2011 (edited) Unbelievable! After reinstalling it just got worse! Now it crashes randomly when navigating (zooming, panning...) WTF?! Edited August 9, 2011 by A.Mitov Link to comment Share on other sites More sharing options...
datacrasher Posted August 9, 2011 Share Posted August 9, 2011 i would contact your store where you brought max and get support Link to comment Share on other sites More sharing options...
Thablanch Posted November 17, 2011 Share Posted November 17, 2011 Having the same problem here.. multiple crashes on save, open or mat. editor, and this on random scenes. Link to comment Share on other sites More sharing options...
datacrasher Posted November 17, 2011 Share Posted November 17, 2011 Thablanch I don't have anymore advice to help with this thread b/c i have said all i know if the adivce did not help then put this question on the autodesk forum or contact your support team! Link to comment Share on other sites More sharing options...
theqball Posted November 18, 2011 Share Posted November 18, 2011 are there any differences between the hardware configs of the two machines? are the graphics cards the same and the same drivers? are the screen resolutions the same and same number of monitors on both systems? Link to comment Share on other sites More sharing options...
marc666 Posted February 26, 2012 Share Posted February 26, 2012 Hi, A. Mitov, This software (3ds max) is very big and complicated software, at a same it is very delicate. Because programer use writes lots of scripting, languages and third party stuffs. And this peoples takes real challenges and set a mile-stone in the market. That's why a 3ds max No.1 in 3d world(+ point). And nobody is perfect. This software uses lots of memory and processor power to produce a single image. We designers only see front-end, in the back-end (data processing) it take data dump, compiling codes, memory management, solving problem, register the tools and after all that we get great results. Sorry, I'm here for give a you solution. Not for discuss the how 3ds max works. Before giving a solution you might know the how 3ds max works. Here is the solution. That might work I guess. 3ds max tools uses lots of windows registry, even a single value give you head-ache. Don't use default windows uninstall wizard, because windows never deletes complete registry values. That why you getting same or worst problems. Use third party uninstallers to uninstall the 3ds max which cleans also the windows registry. (Like: your uninstaller, ashampoo uninstaller or other uninstaller which suits you best.) I think this is best way to get rid of you problem. Link to comment Share on other sites More sharing options...
erkutacar Posted February 26, 2012 Share Posted February 26, 2012 it may not be revelant to max at all.. it maybe ur graphic card or hdd malfunctioning.. take back up of ur project files and try restoring to a week earlier.. then update all of ur drivers including chipset.. Link to comment Share on other sites More sharing options...
joeyt Posted May 14, 2012 Share Posted May 14, 2012 make sure you are not using any Renderer with your Video hardware.Because it makes Material editor confused.of curse it is a progame bug I guess. V ray ok,fianlrender ok,any renderder with CPU only will help. Link to comment Share on other sites More sharing options...
