Change scales?
JasonJohnson
I might be thinking in Max terms but in any case. I'm starting to learn Revit right NOW. No better way to do it then to work through a project at the same time. So I have this CAD file I found on a site. It's in Millimeters. My Revit is set up in feet? I believe thats the default? Anyways I imported the 4 levels into the correct places but my scaling is all off. Since I had it auto detect on import I guess it keep the same measurements from CAD then in the elevations view the levels are set at 10ft high.
So question is. How can I scale these 4 levels down into feet? I been Google searching but this may be the fastest way to find out :)
More questions to come I'm sure! Until then I'm at my first road block that I need to get around. Thanks guys!!
I found this in another thread for CAD
What I will do is:
Copy entire dwg (metric) into imperial template (New-Imperial)
scale entire dwg:
Command: scale
Select objects:all
Specify base point:
Specify scale factor or [Reference]: 0.03937007874016
Change current dim style from usually ISO to Standard
Update dimension
Check dwg for any inconsistency
... anything I miss?
Hope not. That it.
Also found this.... but not sure what it means...
as I don't like typing in those long numbers I use
R
25.4
1
I tried that and seems like every thing in CAD is scaled correctly. I only know enough CAD to clean up a drawing. What the heck did I just do? And was that truly correct?
This is what happened.
25.4mm = 1" or to scale it down: 0.03937007874016 (roughly)
In the future you'll notice that when you import in a CAD file one of your options is import units. If you change those import units to mm (or whatever is appropriate) instead of auto-detect it will be brought in appropriately without the need to use scale factors.
Good luck in your studies!
