bgon Posted August 9, 2011 Share Posted August 9, 2011 Having some serious problems with Vray and SU. Im using SU8 and a demo trial of latest Vray. Vray takes too long to begin rendering on a model which is not complex at all. After it starts rendering finally it takes almost 2 minutes to finish rendering. Im talking the lowest resolution output and the least amount of materials. In another instance vray just does not renders image. Please help, this will benefit a lot of us I know. Thanks'''' Link to comment Share on other sites More sharing options...
Devin Johnston Posted August 10, 2011 Share Posted August 10, 2011 This could be the result of anything, you need to post your render and material settings. Link to comment Share on other sites More sharing options...
M V Posted August 22, 2011 Share Posted August 22, 2011 A high res material map could be the issue. VR4SU usually does not like hi-res maps like Max. If you are using something thats over 1,000 pixels, I would reduce it and try that. Also, parsing times are a bit of pain sometimes with the plug-in, thats just how it is for now. What version are you using and what are your machine specs? Link to comment Share on other sites More sharing options...
