Floaters appear on a non-existing monitor!
The Miff
Hey!
I've just moved to a smaller office and down-sized to a single moniitor. Previously, I used the second monitor for floating windows, such as Frame Buffer, Layers', and the isolate window.
Now that I'm using a single monitor and call up these functions, the floaters don't appear. They're actually being sent to monitor #2...which isn't there!
How do I 'force' them back to monitor #1?
The other windows are there they are just off screen.
There is probably an easier way to do it but this should work.
Make the wayward window active (for example,the layers dialog hit the layers button.)
Hit ALT then the left arrow key (not at the same time). then hit the down arrow key, then hit M (move).
Now use the left arrow key to move the window back on screen.
You can try it out on a dialog you can see like the material editor.
Like I said, there is probably an easier way but I am not aware of it. :)
I had the same problem. 2012 is the only version this has happened to me with. All other versions used to throw everything back to the single monitor when 1 was switched off or disconnected. PC, monitor or graphics settings did nothing.
I ended up grabbing someone elses monitor and dragging everything back accross.
That is a tuff one. I tried a few things but I couldn't find a key that would switch to the isolation window.
There is most likely a entry in the registry that you could change but that would be a hunt to find the right one.
I don't know if reverting to the default setup would do it or not.
If I think of anything I'll let you know. Sorry :)
