armgabriel Posted August 10, 2011 Share Posted August 10, 2011 I currently find it more realistic using vray dome light (Image based lighting) compare to other techniques in lighting exterior scenes... most specially because of just few settings to tweak.. but I cannot manipulate the kind of shadow orientation that I want.. is there a possibility in doing it without disturbing the current position of HDRI background in the viewport? Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 10, 2011 Share Posted August 10, 2011 Yes, you could copy the HDRI map to your material editor and create a duplicate. Copy it to the environment slot and make your dome light invisible. That way you have two versions of the HDRI tht you can control independantly, one for lighting the other for your background. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 10, 2011 Share Posted August 10, 2011 Also I should add that in order to rotate the HDR you will need to change the horizontal rotation value, rotating the dome light won't have any effect. Link to comment Share on other sites More sharing options...
armgabriel Posted August 10, 2011 Author Share Posted August 10, 2011 Yes, you could copy the HDRI map to your material editor and create a duplicate. Copy it to the environment slot and make your dome light invisible. That way you have two versions of the HDRI tht you can control independantly, one for lighting the other for your background. Also I should add that in order to rotate the HDR you will need to change the horizontal rotation value, rotating the dome light won't have any effect. Awesome! Thank you very much Stephen! Link to comment Share on other sites More sharing options...
rafa rubio Posted August 16, 2011 Share Posted August 16, 2011 Check this out.... it is very helpful... http://www.peterguthrie.net/blog/2011/07/hdri-skies-faq/ cheers... Link to comment Share on other sites More sharing options...
armgabriel Posted August 16, 2011 Author Share Posted August 16, 2011 Check this out.... it is very helpful... http://www.peterguthrie.net/blog/2011/07/hdri-skies-faq/ cheers... Thank you Rafa! Link to comment Share on other sites More sharing options...
