Andronikos Posted August 19, 2004 Share Posted August 19, 2004 C4D crashes on my Dual Xeon ! ...the same C4D version and plugins works absolutely fine with my AMD XP 2500+ here is a print screen of the error! Error: Access violation at 0x1AF889E4 (tried to write to 0x0000006C), program terminated please help! thanx! Link to comment Share on other sites More sharing options...
Mike Abbott Posted August 19, 2004 Share Posted August 19, 2004 ...I think your best option is to contact (e-mail) Maxon support directly. Mike A. Link to comment Share on other sites More sharing options...
STRAT Posted August 19, 2004 Share Posted August 19, 2004 hmmm, that file looks familier Link to comment Share on other sites More sharing options...
Frosty Posted August 19, 2004 Share Posted August 19, 2004 Nice Strat!! Gotta be weird to see your work on someone elses screencap. Link to comment Share on other sites More sharing options...
STRAT Posted August 19, 2004 Share Posted August 19, 2004 not when he's crashing all the time Link to comment Share on other sites More sharing options...
Andronikos Posted August 20, 2004 Author Share Posted August 20, 2004 nice shaders by the way... maybe is th disk... yes I am legal... let u know... thanx Link to comment Share on other sites More sharing options...
Andronikos Posted August 21, 2004 Author Share Posted August 21, 2004 ...I still receiving that message and the C4D crash! What I have done: change and reinstall new win xp to new WD160 HD new DDR memory (1gb) from AMD PC new VGA (radeon 9700 pro) from AMD PC ...do not know what I should do? anybody have any ideas? how can I test if the CPU's are ok? or the mobo? ...don't know what else to think... help guys.. I spent so much $$$ for the Dual Xeon system and I can not use it... P.S. sometimes is not crashing especially when I am not using Strat's cool water shaders... I do not know if thet helps... I will test it more and let you know... ...I forgot to mention that the system crashes only when I want to render... (or when rendering the materials - double click mat. @ the material manager) Link to comment Share on other sites More sharing options...
Frosty Posted August 21, 2004 Share Posted August 21, 2004 Well, ithink you need to take your machine into a professional. Although its possible you've hit some bug in Cinema with your particular configuration, I highly doubt that is the problem. The more likely problem is bad software(system or other) or a bad piece of hardware. It seems to me that you need profession diagnostics. Personally, the only time Cinema crashes on me is while using Mesh Surgery, it can be a little usntable. The core app has never cause me issues. Link to comment Share on other sites More sharing options...
mi:ne Posted March 1, 2005 Share Posted March 1, 2005 I registered to this forum when my friend redirected me to this thread just to answer this post =) Anyway... from what I can gather, Cinema4D and SP2 doesn't really like eachother even if Maxon claims they do. But the problem seems to lie in the HyperThread or MultipleProcessor bit. I know cause I have the same problem and have searched the net far and wide without any results or something remotly close to a solution. BUT... by going into the options-screen and changing the threads-setting to 1, 2 or even 4, instead of optimal it seems to run much more stable. I'd say it's even more stable the less CPUs you use. So 1 thread would in this case be "optimal" and not 4 as Cinema seems to believe. The funny thing is that it is pretty much stable if you change the setting to 4 instead of having it set to optimal which automatically gives you 4. I don't know why that is, but it works anyway =P Link to comment Share on other sites More sharing options...
linz Posted September 20, 2005 Share Posted September 20, 2005 im having the same problem. but interestingly, in a different scenario. i am using archicad 9 with the C4D plugin. i save the AC9 file as a .ac4d file. my C4D crashes when i go to open this file in C4D. this is the error i get : error: access violation at 0x00811c74 (tried to read from 0x507878b4), program terminated any advice would be helpful. i tried changing the settings in options, but of course, that is a rendering fix, and it did not help. thank you for your response! im glad i found this website LINZ Link to comment Share on other sites More sharing options...
Frosty Posted September 20, 2005 Share Posted September 20, 2005 Do we know each other lindsay? Link to comment Share on other sites More sharing options...
