CEJ1976 Posted August 16, 2011 Share Posted August 16, 2011 Hi, I am currently testing out 3ds max 2012 having made the step from 2009. However, I can't seem to find the option within the compact material editor that allows me to merge materials directly from other scenes? Can anyone help? Thanks. Link to comment Share on other sites More sharing options...
datacrasher Posted August 16, 2011 Share Posted August 16, 2011 Ciaran You should not need to compact the material once you merge an object into your scene max will take the textures too Link to comment Share on other sites More sharing options...
CEJ1976 Posted August 16, 2011 Author Share Posted August 16, 2011 Thanks, yes materials come across fine when you merge geometry. However, there used to be an option to just merge the material directly from a scene without having to select a piece of geometry?? Any ideas? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 17, 2011 Share Posted August 17, 2011 Click the Get Material button on the Compact Editor and, in the Material/Map Browser, click the "eject" button on the left of the Search by Name field. Link to comment Share on other sites More sharing options...
CEJ1976 Posted August 17, 2011 Author Share Posted August 17, 2011 Rick, Thanks for helping out. I don't seem to have the 'eject' option in my material/map browser though when in compact mode? Attached is a grab of what I see. Cheers. Link to comment Share on other sites More sharing options...
Jan Posted August 18, 2011 Share Posted August 18, 2011 He's talking about the "inverted eject" in your screen grab. In this menu, select "open material library" and use *.max as file type. You can open any max scene only for extract materials in this way. Link to comment Share on other sites More sharing options...
CEJ1976 Posted August 18, 2011 Author Share Posted August 18, 2011 Thanks Jan, thats brilliant (knew it had to be there somewhere). Cheers. Link to comment Share on other sites More sharing options...
