Guest eddie57 Posted August 16, 2011 Share Posted August 16, 2011 I recently installed AutoCAD Architectural Release 3 on my new PC. My PC has Windows 7, 64 bit OS installed. After I installed ADT 3 I started using the program with no problems until I tried using the submenus under the Design Menu. When I click on a submenu, for example, "Walls", I get the following message? AecWallAdd Unknown command "AECWALLADD". Press F1 for help. Does anyone know what I can do to get the submenus to function? Any help is appreciated. PS: I tried the "Repair" function, but that didn't help. Thanks. Eddie Link to comment Share on other sites More sharing options...
Cad64 Posted August 20, 2011 Share Posted August 20, 2011 ADT 3 is pretty old, (Released in 2000 I believe), and it is a 32 bit application. So getting it to run perfectly on a 64 bit Win 7 machine may be difficult. But having said that, try the MENULOAD command. There may be some menu files that need to be loaded. Link to comment Share on other sites More sharing options...
