zewanil Posted August 16, 2011 Share Posted August 16, 2011 Hello there i having this problem with the reflection on the 1 first pic I would like that it look a bit like the 2 pic ( hiding the window ) but with a little reflection so you can still see the window glass... Does anyone have a idea about what i am doing wrong ? Here is little idea of the scene *( pic 3 ) thanks for your help Link to comment Share on other sites More sharing options...
AubreyM Posted August 16, 2011 Share Posted August 16, 2011 What are your IOR and reflection settings? Is the affect shadows option checked? Glass is pretty easy in vray. IOR should be 1.1 - 1.6 or so. Ref glossiness at 1.0 for crisp reflections or a little less for a little blurrier reflections. The diffuse color should be black. The reflection color should be a light grey. The refraction color should be white. Fresnel reflections should be on. You could also check reflect on backside. Link to comment Share on other sites More sharing options...
zewanil Posted August 19, 2011 Author Share Posted August 19, 2011 thanks for your help Link to comment Share on other sites More sharing options...
AubreyM Posted August 19, 2011 Share Posted August 19, 2011 I hope it did help Did it turn out ok for you? Link to comment Share on other sites More sharing options...
aristocratic3d Posted August 21, 2011 Share Posted August 21, 2011 Play with IOR. and the suggestion that Millard gave. >>The reflection color should be a light grey. Link to comment Share on other sites More sharing options...
