aggster Posted August 19, 2011 Share Posted August 19, 2011 Hi everyone. I have a problem with 3ds max 2010 64-bit and VRay 2.00.02. My grafic driver are Direct 3D 9.0 (Nvida Quadro 600). The problem is in the perspective viewport when I use Vray lights. It all turn black (as in no lights, only black and grey) when I for example hit ctrl+z or when I flip ctrl+w to maximize viewport. I can however use ctrl+l to switch on default lightning to see lights in my scen but that doesn't solv the problem. When the perspective viewport is black (after hiting ctrl+z, even if the ctrl+z doesn't have anything to do with the lightning) I can click in the perspective viewport and that makes it go back to normal vray lightning. But I have to click in the viewport every single time to make it work. Any suggestions? This problem doesn't affect my renderings - that part works fine! I'm not sure if this problem are caused by 3ds, vray or my grafic driver. But my suggestions are on vray. Thanks! Link to comment Share on other sites More sharing options...
