servarus Posted August 20, 2011 Share Posted August 20, 2011 (edited) I'm learning how to use V-ray, and currently using version 2.0. I'm not sure why though, maps/texture does not appear in the final render. I tried using the given sample scene from http://www.vray-materials.de/ and then used the material that I am having a problem with, which is almost all, the material appears. I tried to compare the settings, but sadly I am not that expert to know which is giving me this problem. Attached is the scene files and settings. Is it the materials setting or V-ray setting? EDIT: Seems like, when I use planes as the base model and applied the material, it appears. It is because of the modelling method? Edited August 20, 2011 by servarus Link to comment Share on other sites More sharing options...
AubreyM Posted August 20, 2011 Share Posted August 20, 2011 I'm not clear on what your problem is. Is there one material that is not showing up when you render? If so which material? Does it show up in the perspective viewport? Link to comment Share on other sites More sharing options...
servarus Posted August 20, 2011 Author Share Posted August 20, 2011 I'm not clear on what your problem is. Is there one material that is not showing up when you render? If so which material? Does it show up in the perspective viewport? Almost all material I am using is not appearing. And I think I can say it does not appear in the view port, it just change in colors. Link to comment Share on other sites More sharing options...
AubreyM Posted August 20, 2011 Share Posted August 20, 2011 You need to read up on the Vray Camera, having your light multipliers at 150 isn't a good idea. See this link for information on what all the different camera settings do. If it's to much try a standard camera. http://www.spot3d.com/vray/help/150SP1/examples_vrayphysicalcamera.htm Link to comment Share on other sites More sharing options...
servarus Posted August 20, 2011 Author Share Posted August 20, 2011 Does the camera going to effect the material maps? Link to comment Share on other sites More sharing options...
AubreyM Posted August 20, 2011 Share Posted August 20, 2011 What material specifically are you having a problem with? Link to comment Share on other sites More sharing options...
servarus Posted August 20, 2011 Author Share Posted August 20, 2011 Currently the carpet and the wood. I used planes, and the materials shows. I wonder if the modelling method has effects on maps? Thanks for the example on lighting. Link to comment Share on other sites More sharing options...
AubreyM Posted August 20, 2011 Share Posted August 20, 2011 Yes, having all of those separate planes for the floor is a bad idea. You also need to apply a UVW Map to the objects. Link to comment Share on other sites More sharing options...
servarus Posted August 20, 2011 Author Share Posted August 20, 2011 I was trying to emulate a tatami mat effect. Showing differences in panels and so on. I used AutoCAD to do the modelling, maybe the problem starts from there I guess. UVW map fixed the problem. So in a simple way, the error is the object has no "surface" for the map to be shown is it? Link to comment Share on other sites More sharing options...
AubreyM Posted August 20, 2011 Share Posted August 20, 2011 Yup, you got it Link to comment Share on other sites More sharing options...
servarus Posted August 20, 2011 Author Share Posted August 20, 2011 Alright. Thank you very much for the prompt help. Appreciate it. Link to comment Share on other sites More sharing options...
