CEJ1976 Posted August 25, 2011 Share Posted August 25, 2011 Hi, Does anyone have an interesting technique to simulate a flourescent light tube flickering as it turns on? Cheers. Link to comment Share on other sites More sharing options...
BrianKitts Posted August 25, 2011 Share Posted August 25, 2011 you could easily animate the lights intensity flickering high and low a few times if you want a max based solution. You could also take it a step further to render out a selection matte for the bulb and give it some play with a glow in aftereffects to really give it some life in the scene. Link to comment Share on other sites More sharing options...
Camby1298 Posted August 25, 2011 Share Posted August 25, 2011 you could easily animate the lights intensity flickering high and low a few times if you want a max based solution. You could also take it a step further to render out a selection matte for the bulb and give it some play with a glow in aftereffects to really give it some life in the scene. Using the wiggle expression within aftereffects would be the way I would go about it as well... Link to comment Share on other sites More sharing options...
