pri_204 Posted August 25, 2011 Share Posted August 25, 2011 hiya, m doing a 3d project for my class but m stuck at the lighting part in mental ray..i cant seem to get the photometric and i es lites to work properly...plz help... below is the picture...it has an ies light..but it doesnt show..nor the photometric lites either thanks Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 25, 2011 Share Posted August 25, 2011 are you using some other lights besides the IES? do you have any exposure applied in your camera? If you combine, MR Sun/Sky from the exterior you may need to adjust your exposure of the camera and intensity of your IES to match the Sun intensity. Link to comment Share on other sites More sharing options...
Justin Hunt Posted August 25, 2011 Share Posted August 25, 2011 Try using "non-physical" and set you own scale in the mr-photographic exposure control. Also lower the mrsun intensity. If your using photons, play with the photons energy scale. jhv Link to comment Share on other sites More sharing options...
pri_204 Posted August 26, 2011 Author Share Posted August 26, 2011 i'm using omni's as fill lites for the rooms! also i adjusted the mr suns intensity...it helped a bit. but still it aint giving a proper output . m not using photons or GI as it lowers the rendering time i need to make a walk-through which will lower the render time even more. Link to comment Share on other sites More sharing options...
