aristocratic3d Posted August 27, 2011 Share Posted August 27, 2011 Hi guys! Looks like this forum is almost dead. I got a question for you btw, 1. Do you render fires into your scene directly? or you render it and save image sequence and then PP with AE? 2. When I save fires it shows well in max render frame window but does not look same in the saved image file. I tried different format and gamma settings! Please advice,. Thanks Abdullah Link to comment Share on other sites More sharing options...
luthias42 Posted August 27, 2011 Share Posted August 27, 2011 I will normally render my fire separately and then composite it in via After Effects. As far as formates it really depends, if I can get away with tga's I go that way other wise I use tiff's. Hope this helps Link to comment Share on other sites More sharing options...
