wasteland giant Posted August 31, 2011 Share Posted August 31, 2011 trying to render multiple images but I need the vray split channels what's currently happening is: The images render out via batch render but the split channel file will overwrite each other so I will only end up with 1 set if I do a batch render. The only way I'm doing them now is sitting here waiting for each image to render then as it finishes, copying the split channels to a different folder so they don't overwrite. Help~~ Max 2010 Vray 1.5 Sp5. Thanks!! Link to comment Share on other sites More sharing options...
Thablanch Posted August 31, 2011 Share Posted August 31, 2011 What about saving as .vrimg..... A little bit of manual work after, but you can extract the channels you want from there. http://www.spot3d.com/vray/help/200R1/tools_vrimg2exr.htm Link to comment Share on other sites More sharing options...
Arch.Hany Posted May 10, 2012 Share Posted May 10, 2012 i Found a way of doing it You Can Do it by assigning a different frame for every camera for example : camera 1 : frame start and end both at Zero Camera 2 : Frame Start and end both at 1 camera 3 and so on Link to comment Share on other sites More sharing options...
