New build advise
None of their part lists are the part list I have???
  AJLynn said:
That's understandable. I wasn't happy to read that story either. If you instead go to 3datstech.com and click any of the Newegg parts lists, then make your order, a commission will go to 3DATS, which is a CGarchitect partner.
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
AJ,
WOW!!!!
Hate to say I ordered my HP ZR24w before learning about the commission (all the remaining items will be ordered in the middle of next week and I will click through 3datstech.com to Newegg for your commission) but WOW this monitor is nice and AutoCAD at 1920 x 1200 is great -- like double the real estate!
And this is a VERY bright minotor - I actually had to cut the brightness down to about 50% to avoid sunburn!
Thanks, AJ! Awesome monitor.
What's your cooling options? Are you fan cooling or liquid cooling? I skimped on liquid and went to fan cooling and while the fan cooling does the job, it's still letting my temps get pretty high.
I use RealTemp to monitor my CPU temps during render times, and 100 degrees C is near fail for the i7, or at least when the i7's start scaling back, and rendering usually pegs me at around 90C or higher.
I'm looking at putting liquid cooling in as we speak.
I'm pretty sure that a heat sink & fan come with the Intel i7-980 and the case seems to have gone overboard with cooling fans. I'm not going to be animating any video clips for Lucas Films or Industrial Light and Magic or running any 15-hr renders so I should be ok...
The dual dual-core-Xeon I work on now, from 7-yrs ago, has never had a cooling problem, and I am not looking to increase my work-load exponentially by a factor of 20 just to test the cooling -- it was just time for a new computer and I wanted the most bang I could get for my buck.
I do not game or over clock – factory fast is fast enough for me. If it gets too hot I will buy a small refrigerator and put the box in the refrigerator :-)
  karlar said:
Yes. Intel Intel 320 Series SSDSA2CW160G3K5 2.5" 160GB SATA II MLC Internal Solid State Drive link
Only thing I'm a little worried about is that Win 7 64 used up over 25% of the drive already... All my data is always on other drives but I still have a few programs to load so we'll see what happens...
if you installed win7 64bit and it ate up 40gb of space, you did something wrong during your install.
Any idea what I could have done wrong? I followed the instructions to the letter...
Just like my last build you usually find out a few things you 'shoulda' done so once I get through all the basics I'll probably format the drive and start over.
Edited by karlar
Recoving from a soft shutdown (low power state) on an SSD is faster than recovering from hibernation on an HDD. Even booting from a full shutdown on a system with the OS installed to the SSD does not take so long that it would be annoying, in fact I almost find that each time I boot up it justifies the purchase. It takes longer on my latest i3 build to warm up the UEFI on the mobo than it does to warm up Windows 7, and that is just because there has to be a time delay for human reaction to access the UEFI!
EDIT: Forgot the whole reason I was posting in the first place. The i3 I mentioned above, I did the same thing. Ran WinDirStat and found Hibernation to be the culprit. I have 16GB of RAM in that system and the OS is installed on a 40GB SSD! I had less than 5% disk space left, thus the reason I ran WinDirStat :o
Edited by beestee
  • 3 months later...
AJ...
The computer has been utterly fantastic, except for one thing I can't even begin to comprehend! When I do a render, in 3DS 64bit or in SolidWorks 64bit, my task manager physical memory usage will NOT exceed 3.25-3.27gb of memory, and I have 24gb installed????
All 12-threads of the processor max out but that memory thing has me wondering...
Hope you have some good ideas for pointing me in the right direction and, thanks again in advance!
It might just be that your renders don't need more. Alternatively, depending on which renderer you use, I do believe there is a memory limit function in the render settings in Max... I don't have a computer with Max on hand to look at but I believe it's under System...
