radioVOY Posted August 22, 2004 Share Posted August 22, 2004 i have problems cos' i need to animate a loft. i have a shape and i need to extrude it from a defined spline path, the problem is that i need to render all the growing effect. do you have any method to do this?? easy or complex please share. thanks in advance. Link to comment Share on other sites More sharing options...
William Alexander Posted August 22, 2004 Share Posted August 22, 2004 Software? If you are using Max6, there is a help tutorial that shipped with it about having a pen apply worded text to paper, using extrusion to spline. Looks like the pen is drawing out the text. Sounds very similar to your project. Cheers WDA Link to comment Share on other sites More sharing options...
radioVOY Posted August 22, 2004 Author Share Posted August 22, 2004 im trying with both max 6 and viz4. sound similar, to be more specific a need something similar of the HD project of this guys (k+d lab) http://www.kdlab.net/ check all the site its superb. Link to comment Share on other sites More sharing options...
abicalho Posted August 22, 2004 Share Posted August 22, 2004 VIZ 4 does not animate modifiers, splines, etc. MAX 6 does that and it's pretty easy to do so. All you have to do is create your Loft using "Instance" and then animating the original object - the loft will be animated automatically. Alexander Link to comment Share on other sites More sharing options...
radioVOY Posted August 23, 2004 Author Share Posted August 23, 2004 thanks for the tips, but in this case pathdeform is the answer. thanks William for the reference the pen tut in max 6 gime all the answers. thanks for the help. Link to comment Share on other sites More sharing options...
William Alexander Posted August 23, 2004 Share Posted August 23, 2004 radioVOY, Glad it helped, I'd check out Alexander's solution also! I believe it to be more flexible and possible to create as you go. Wm Link to comment Share on other sites More sharing options...
