alzain Posted August 22, 2004 Share Posted August 22, 2004 hello, im usuing autocad for modeling then from max6 - (trail version) i import the dwg files. now when i was using max5 the import window was soo easy and has control over the objects for example it group certain objects in one layer and you can open close the group and make sub selection wich is very helpful BUT in max6 when you import dwg files all the objests in a certain layer will be as one object and you have no option to make sub-selection.??????????????????? and if you uncheck the - combine object by layer - all objects will be given the name 3dsolid which is veeeery diffcult to identify?????? also this prefix problem LAYER im wondering if there is way to have more control onto the imported objects within the same layer. like max5 style thanks and regards Link to comment Share on other sites More sharing options...
kicks Posted August 22, 2004 Share Posted August 22, 2004 Link to comment Share on other sites More sharing options...
colorID Posted August 22, 2004 Share Posted August 22, 2004 hi, i dont know what exaclty is the problem in max6 i ve been using it in coordination with autocad and it is perfect,well when u export objects that is in one layer.. it will turn into editable mesh, and through it u can select any object by element. Link to comment Share on other sites More sharing options...
alzain Posted August 22, 2004 Author Share Posted August 22, 2004 hi guys ,,,, the problem is that in max 5 when i use to import dwg files from acad 2000 all objects that are in certain layer will be grouped in one group and then you can open to make sub selection modify .....etc which is very helpful but im max6 all the objects in a certain layer will be as one object also the prefix which will be added to the orignal name of the layer for example layer named (wall) in acad in max6 will be l(ayer wall) ???????????/ thnks for your replies zain Link to comment Share on other sites More sharing options...
Jennifer Posted August 22, 2004 Share Posted August 22, 2004 Turn off the "Combine Objects by Layer" option in the Import dialog. In the documentation it describes it as renaming, but it also combines the objects, as the option's name implies, into single objects based on the layer they are on. Link to comment Share on other sites More sharing options...
alzain Posted August 22, 2004 Author Share Posted August 22, 2004 hi jeniffer,,, i tried that if i do that all the objects will be given the name 3dsolid which will very diffucult to identify them Link to comment Share on other sites More sharing options...
Tom Hamelrijckx Posted August 22, 2004 Share Posted August 22, 2004 'layer' prefix can easily be removed with the rename tool (remove first six characters on selected objects). This weekend I experienced another thing with dwg importing however. No matter how high the isolines are put in creation of an extruded curved polyline in ACad, Max will import only few (too few). So working with 3ds is still necessary. Link to comment Share on other sites More sharing options...
abicalho Posted August 22, 2004 Share Posted August 22, 2004 In AutoCAD objects do not have names. They are organized by Layers. That's how you have to think of them in 3dsmax 6. Naming them 3dsolid01, 02, 03 makes little sense too. Alexander Link to comment Share on other sites More sharing options...
Jennifer Posted August 22, 2004 Share Posted August 22, 2004 The DWG Import filter still puts them onto the layer that they were created on in AutoCAD, so you can tell basically what they are by the layer, correct? I'm not sure what else it would pick to call the objects, anyway, since you can't define names in AutoCAD, just layer names, and it has to do something with the little darlings. Link to comment Share on other sites More sharing options...
alzain Posted August 23, 2004 Author Share Posted August 23, 2004 hi guys: abicalho: i wish it was the way you said the problem all the objects will be named 3dsolid - NO numbers ex: 3dsolid 3dsolid 3dsolid 3dsolid 3dsolid even i tried to copy the dwg import plugin in max5 to max6 but i didnt work? Link to comment Share on other sites More sharing options...
abicalho Posted August 23, 2004 Share Posted August 23, 2004 I know they're all listed 3dSolid. Look at your layer dialog. Does it have Layers? Do they match the names of the layers in ACAD? YOu have to think about them as you do in ACAD - think about layers, use layers. The MAX 6 importer is new, different from the MAX 5 one. If you want the MAX 5 importer inside of MAX 6, get the File Link extension and then you'll have the Legacy AutoCAD importer there. Alexander Link to comment Share on other sites More sharing options...
alzain Posted September 4, 2004 Author Share Posted September 4, 2004 hi abislalho : can please tell me how to do the that please ???? Link to comment Share on other sites More sharing options...
abicalho Posted September 4, 2004 Share Posted September 4, 2004 Here: http://www4.discreet.com/subscription/subscription.php?id=432#file If you're not a subscription member, I suggest talking to your reseller. Alexander Link to comment Share on other sites More sharing options...
