Gary Ledgerwood Posted September 7, 2011 Share Posted September 7, 2011 Studio/Institution: SelfGenre: Commercial ExteriorSoftware: Sketchup, 3DS Max, PhotoshopDescription: Here is an early preliminary design for a hotel addition. I am sure this will evolve a lot over the coming months and I will do my best to post updates. Comments and crits are welcome. Link to comment Share on other sites More sharing options...
AubreyM Posted September 7, 2011 Share Posted September 7, 2011 Love the building. Brick textures could use some work and a better background but you said it's a wip so you probably know that already Looking forward to the updates. Link to comment Share on other sites More sharing options...
aristocratic3d Posted September 9, 2011 Share Posted September 9, 2011 Did you modeled the interior or was just textures? If they are modeled then it does not look that good. If texture then its nice. Link to comment Share on other sites More sharing options...
aristocratic3d Posted September 9, 2011 Share Posted September 9, 2011 I also did not like the oily and reflective concrete in front of the building. Link to comment Share on other sites More sharing options...
Gary Ledgerwood Posted September 9, 2011 Author Share Posted September 9, 2011 Thanks for your comments! Yes, those are textures in the windows. As this project evolves I plan to model the interior. And your point is noted about the asphalt. I have yet to find or create a texture I am satisfied with. Link to comment Share on other sites More sharing options...
Red33 Posted September 14, 2011 Share Posted September 14, 2011 Looks great! I would try to get the whole building into the picture if possible. I would also add to the foreground to soften the image a bit and reduce the amount of asphalt. Would you mind sharing your work flow for adding the textures in the windows? Link to comment Share on other sites More sharing options...
Gary Ledgerwood Posted September 15, 2011 Author Share Posted September 15, 2011 Looks great! I would try to get the whole building into the picture if possible. I would also add to the foreground to soften the image a bit and reduce the amount of asphalt. Would you mind sharing your work flow for adding the textures in the windows? Thanks for the input Randy. As I progress further into this project, I will be looking at other views that will incorporate the entire existing building. This view was my first shot at a design to give the client an idea of our direction. I agree with your comments and will definitely embellish the foreground as I develop the design further. This particular image was produced under a pretty short timeframe. As for the windows, I went to cgtextures.com and found some night window images... http://cgtextures.com/textures.php?t=browse&q=51213 Then I applied them to planes behind the glass and added self illumination. I use Mental Ray, so it is just a simple A&D material and then copy the diffuse map into the self illumination (glow) slot. Check both glow options boxes and adjust the luminance values to your liking. Hopefully this makes sense... Its not the best method but its a whole lot faster than modeling the interior. ) Link to comment Share on other sites More sharing options...
Red33 Posted September 24, 2011 Share Posted September 24, 2011 Thanks for the info! I use vray for sketchup, but I get the idea. I used the technique in my last post in the forum and I think it worked great. I look forward to using it more often in the future. I'm getting more requests for evening shots lately, so this was definitely helpful! Link to comment Share on other sites More sharing options...
Gary Ledgerwood Posted September 27, 2011 Author Share Posted September 27, 2011 Thanks for the info! I use vray for sketchup, but I get the idea. I used the technique in my last post in the forum and I think it worked great. I look forward to using it more often in the future. I'm getting more requests for evening shots lately, so this was definitely helpful! Great! Glad it was helpful. I will check out your results. Link to comment Share on other sites More sharing options...
aristocratic3d Posted October 8, 2011 Share Posted October 8, 2011 Thanks mate for sharing the info. the job was great. I am benefited from your info. Thanks for the input Randy. As I progress further into this project, I will be looking at other views that will incorporate the entire existing building. This view was my first shot at a design to give the client an idea of our direction. I agree with your comments and will definitely embellish the foreground as I develop the design further. This particular image was produced under a pretty short timeframe. As for the windows, I went to cgtextures.com and found some night window images... http://cgtextures.com/textures.php?t=browse&q=51213 Then I applied them to planes behind the glass and added self illumination. I use Mental Ray, so it is just a simple A&D material and then copy the diffuse map into the self illumination (glow) slot. Check both glow options boxes and adjust the luminance values to your liking. Hopefully this makes sense... Its not the best method but its a whole lot faster than modeling the interior. ) Link to comment Share on other sites More sharing options...
koldo Posted June 26, 2012 Share Posted June 26, 2012 woah...impressive! 3D RENDERING Link to comment Share on other sites More sharing options...
Mario De Achadinha Posted June 26, 2012 Share Posted June 26, 2012 Great work but do something with regards to the concrete. Link to comment Share on other sites More sharing options...
jaymari Posted June 26, 2012 Share Posted June 26, 2012 Very artistic. the hotel is very cute and personalized design. Link to comment Share on other sites More sharing options...
