Setting up Vray render slave
Brodie Geers
Yep - You will need to go to Chaos Group Licensing menu - Administration - Change V-Ray Client License Settings and ensure that the slave knows the IP addresses of the workstations that have dongles attached. (this occurs during the install process anyway). It's helpful to have static IP addresses. If it's DBR your using, run Vray Spawner on the slave and set the IP addresses in the render dialoge DBR settings and you should be ready to go.
