blaz Posted September 8, 2011 Share Posted September 8, 2011 Hi, I have linked a topo dwg file to my revit file to create the topo surface. Here are the steps, kindly let me know if i missed a step. 1. Link the cad file uncheck the curernt view only, preserve, mm, auto center to center 2. turn on the survey point 3. edit the object scale to 1000 after this step, i am unable to select the linked cad anymore. i was able to create this during my 30 days trial period. somehow when we register our license, this problem appears. any bugs issue for this revit architecture 2012? thank in advance. Link to comment Share on other sites More sharing options...
blaz Posted September 8, 2011 Author Share Posted September 8, 2011 I have the same issue with autocad 2012 that come with the bundle as well. once i scale the survey drawing to mm unit. the lines seems out of the limit kind of problem. Some of them are disappear. anyone have the same issue? I found the service pack from autodesk (est. 3 over Gb with the so called first ship things) I will try whether this is a bug issue from the software. Link to comment Share on other sites More sharing options...
blaz Posted September 8, 2011 Author Share Posted September 8, 2011 Problem solved. It is the units issue. quite a different from 2011 version Link to comment Share on other sites More sharing options...
