vru Posted August 22, 2004 Share Posted August 22, 2004 Hi All I have a video project edited in Adobe premier. I have also used after effects in the video. The video Format: Quicktime Video (.mov) Resolution: 640x480(4:3) Frame Rate: 29.97 Compression: Sorenson Video 3 Duration : 7mins The file size is 1.64 gb. The video skips when I try to run it on my laptop. Also the file size is so big that I cannot write it to CD. How can I make a Video CD of the project? Thanks Vrushali Link to comment Share on other sites More sharing options...
mtutaj Posted August 22, 2004 Share Posted August 22, 2004 Here is a link that might help. http://www.videohelp.com/ Mike Link to comment Share on other sites More sharing options...
anvaraziz Posted August 23, 2004 Share Posted August 23, 2004 convert the mov file to avi (better use divX to compress) open nero ..... start make Video CD -select the avi file -BURN thas all........... Link to comment Share on other sites More sharing options...
tony3di Posted August 23, 2004 Share Posted August 23, 2004 Hi Normally VCD is made with a more universal codec, and that is mpeg 1. Check your premiere for a Mpeg exporter. if you can´t find one check the web for some free versions. Why Mpeg1? good quality over compression and easy distribution because all computers regardless of the video codecs they have installed can read MPEG1 and that´s what we want with VCD. Sizes must be 4:3 320x240 or 640x480. Link to comment Share on other sites More sharing options...
