doujay888 Posted August 23, 2004 Share Posted August 23, 2004 I've been using Max for quite some time now, however, til now I haven't improved much on my lighting I've tried radiosity on several attemps yet I can't get thru it. Im more familiar with the standard lights but the bottomline is Im not yet happy with the results of my work! can you give me suggestions on how to improve my lighting? I have attached an image using standard lights.... I need your suggestions on it, please? My PC Config: P4 2.80 Ghz. 1 GB RAM Thanks in Advance, Dennis Link to comment Share on other sites More sharing options...
anvaraziz Posted August 23, 2004 Share Posted August 23, 2004 where is image,,,,,,,,,,, Link to comment Share on other sites More sharing options...
doujay888 Posted August 23, 2004 Author Share Posted August 23, 2004 image is attached now, kindly check pls! and give me some suggestions. thanks, dennis Link to comment Share on other sites More sharing options...
django Posted August 23, 2004 Share Posted August 23, 2004 ok. what kind of light did you use? as ican see i think its an omni light? (correct me if im wrong).if it is omni then try to shift to a photometric light.. Link to comment Share on other sites More sharing options...
ipdesigner Posted August 23, 2004 Share Posted August 23, 2004 kabayan!.. im using radiosity most of my rendering ryt now..try to check the settings that i suggested to ACHENG...(in this forum also, work in progress) good luck! Link to comment Share on other sites More sharing options...
Acheng Posted August 25, 2004 Share Posted August 25, 2004 hi dennis, i also encounter the same problem. yup, it's better to use photometric light rather than using standard light. that's because standard only produce direct light only and u need to add more light to simulate the indirect light. U can try to read the radiosity reference supply by max. there u may find a lot of information about radiosity. i already see ur images, how long did u take to do the lighting? from my experience, i found it's hard to visualize the indirect light by our judgement or prediction. ur image is good if it's from standard light. u may look the the instruction by our good member( Sherwin Boston). he suggested and teached me alot about the problem,. here i thank to him. because he changed my opinion about the complexity of radiosity. regard, acheng Link to comment Share on other sites More sharing options...
kicks Posted August 25, 2004 Share Posted August 25, 2004 talking about fakeiosity: (which comes in real handy if time constraint is an issue) Link to comment Share on other sites More sharing options...
Mokiloke Posted August 26, 2004 Share Posted August 26, 2004 There is a fantastic tutorial that is really worth doing if you're interested in fakiosity. It the montree one in the tutorial section of this web site. THis is the most important in your case but you should do some of the others as well http://www.cgarchitect.com/resources/tutorials/smoke3d/tutorial3.asp Link to comment Share on other sites More sharing options...
