max.m Posted September 14, 2011 Share Posted September 14, 2011 Hi, generally i use a vray displacement modifier on an extruded spline to create grass. Now i face the problem that i need grass on a flat roof for bicycles and see the displacement of the Grass object from below. Can someone tell me how to make the displacement only in one direction? Link to comment Share on other sites More sharing options...
sanmb Posted September 15, 2011 Share Posted September 15, 2011 Convert it to edit poly and detach the polygon and apply displaced material to polygon. Link to comment Share on other sites More sharing options...
max.m Posted September 16, 2011 Author Share Posted September 16, 2011 i use the vray displacement modifier, not a material with displacement! when i detach a polygon and add the vray displ. mod. the result stays the same. i get the dispersion on both sides of the polygon, what i want to avoid! Link to comment Share on other sites More sharing options...
sanmb Posted September 18, 2011 Share Posted September 18, 2011 Hi Max, It works for v-ray displacement,you can hide unwanted surface by creating other object or copying the same and scaling.......... Link to comment Share on other sites More sharing options...
