torwada_13 Posted September 20, 2011 Share Posted September 20, 2011 hi, i really need your help about the glass in windows, i really need it glossy, reflective and a little bit refractive but the interior is too dark Link to comment Share on other sites More sharing options...
AubreyM Posted September 20, 2011 Share Posted September 20, 2011 Make sure "affect shadows" is checked for the material. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted September 21, 2011 Share Posted September 21, 2011 You could also look into rendering the interior on a separate pass and be able to control the brightness in post to your liking via that interior only layer. Link to comment Share on other sites More sharing options...
nelpiper Posted September 22, 2011 Share Posted September 22, 2011 If you´re using vray2, you could use the vraylightselect pass to increase the interior lighting. Scott is right. IMHO, you cannot afford to do the work today without using vray passes. The make your life better off 300% Link to comment Share on other sites More sharing options...
