Distributed rendering - Queue Monitor
CEJ1976
Hi,
I have recently started using distributed rendering which is great. I was wondering if there was a way of combining distributed rendering with a queue monitor so that I can submit a bunch of jobs to be rendered one after the other by distributed rendering?
Cheers.
You can use backburner and submit the job to you main workstation, when it begins rendering it will also use your distributed rendering machines. Make sure you leave distributed rendering turned on in V-ray:System settings or it won't work. Alternatively you could use the split scan line feature in backburner to kind of do the same thing but you'd have to pre render your light maps for it to work properly.
