"Pulling" an animated material through an object
Jonathan
You could use a blend material perhaps, with an animated mask map. Depending on what you are doing you may need seperate UVW mapping channels for each map. Your mix mask might be a gradient or animated noise of some kind. If this mask has a different mapping channel from the first two diffuse materials you could animate the UVW mapping gizmo to "reveal" the transition between the first two colours.
Edit: sorry replied the same time as Flint above :)
Edited by Bruce Hart
Do it in post. Render the bare wall and the brick wall separately. Then in say, After Effects, there is a already built layer transition that mimics something being painted on. Or you can create your own mask in AE just as easily.
Post will save you on re-rendering headaches and gives instant feedback. You don't always have to do stuff like this in Max or as a baked in render.
