simunlastre Posted September 28, 2011 Share Posted September 28, 2011 hello, im new in 3d... i have made stairs and i have a rock texture for it so i have to map it and add displacment to... i have tryed uvw map but dont work, i know i have to unwrap uvw but i cant figure out how to do it so i need some help here are my stairs... [ATTACH=CONFIG]45098[/ATTACH] Link to comment Share on other sites More sharing options...
simunlastre Posted September 29, 2011 Author Share Posted September 29, 2011 here is an exsample of what i am trying to do... here is an angle where the blue lines presents where texture match properly and red line wrong, how to map that texture match properly on all sides?? [ATTACH=CONFIG]45109[/ATTACH] Link to comment Share on other sites More sharing options...
pailhead Posted September 29, 2011 Share Posted September 29, 2011 pa ovo je samo uvw unwrapovano i mapirano isto kao kada bi uzeo da napravis kocku od papira. Ne moze da se spoji na ovjo desnoj vici pa sta god da uradis, osim ako nemas VRLO specificnu mapu, ili nesto proceduralno. The easiest way to achieve this is to do a simple loft... Loft will map this by default. Then you start charging 8-12 bucks an hour, and leave someone in the developed world homeless Link to comment Share on other sites More sharing options...
nilesh1234 Posted October 1, 2011 Share Posted October 1, 2011 Frist of all u have to check the texture is seamless or not if it is u can use uvw map for that it will help u a lot Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted October 1, 2011 Share Posted October 1, 2011 Seamless texture won't solve the corner problem. You might be able to throw something together with a planar map oriented on the diagonal towards the corner but that will probably have ungly zigzagging and stretching. Link to comment Share on other sites More sharing options...
nilesh1234 Posted October 2, 2011 Share Posted October 2, 2011 have u try uvw unwrapping it will help u the corner problem Link to comment Share on other sites More sharing options...
pailhead Posted October 2, 2011 Share Posted October 2, 2011 ... His original question was about the stairs. The stairs can be simply mapped, by modeling them with a loft. It doesnt even cause any mapping issues. The box on the other hand, is a completely different topological issue, and can't even be addressed with 3d properly. What Peter said is correct, but then you're going to go highlight the edge on the oposite corner and go "wtf, what's all this stretching". Other than painting the rocks in something like zbrush (not sure if bodypaint is still around) youll never be able to get this to map the way you want them. But yeah: u try uwv unwrap, that going to do u good w00t. Link to comment Share on other sites More sharing options...
