sparksue Posted September 29, 2011 Share Posted September 29, 2011 Hi everyone, Would appreciate anyone can guide me how to brighten the outside that i create? (notice the outside view is very dark..but in real life, should be very bright.) Any suggestion to made it brighter? Thanks! [ATTACH=CONFIG]45099[/ATTACH] Link to comment Share on other sites More sharing options...
Jeggy Posted September 29, 2011 Share Posted September 29, 2011 Hi, it depends on what are you using as an background. If you are using a plane with assigned material you should use vray light material with bitmap in colour slot. If you are using a bitmap in environment background slot you should try uncheck the "affect background" in colour mapping. Link to comment Share on other sites More sharing options...
sparksue Posted September 30, 2011 Author Share Posted September 30, 2011 Hi Jeggy, Thanks for your help. Appreciate it. Yup, i am using the 1st option where i include the material as a bitmap in colour slot. Meaning instead of just normal vray material, i will assign it using vray light instead. But i should able to brighten the bitmap by increasing the light. Am i right to say that? Appreciate your advice. Link to comment Share on other sites More sharing options...
Jeggy Posted September 30, 2011 Share Posted September 30, 2011 Of course, if you use vray light material instead of normal vray material you can adjust it`s brightness at material editor by icreasing or decreasing the multiplier of the vray light material. Glad to help. Link to comment Share on other sites More sharing options...
sparksue Posted September 30, 2011 Author Share Posted September 30, 2011 Yup, it's work! I brighter the vraylight mapping and look exactly what i want. Thanks! Link to comment Share on other sites More sharing options...
