Photometric Lights Samples noise in Rendering
NeWAcEiN
weird i have never seen that before once i use the daylight system i switch to external daylight Logarithmic then render Soumitra, maybe it's because your using the photometric lights with the daylight system. Now to think are you using any glow effect in your scene? if not when you delete the daylight system or the photometic light now it go away?
yp it goes away
ill explain the problem in depth say i have nice room mr sun&sky outside light portals on windows photographic exposure preset is selected in that daytime interior is selected now i have a ceiling which has light openings say 2 lights. here no i add photometic light turned shape visible on samples set to 32 shape visible is on dimming is on now when i render the image wherever i gave glossy satin materials lights gives noise NOW WHAT CAN I DO??????????? or what i m not doing right????
I have come across this before. I narrowed it down to the visible light setting and regardless what i did i still got spotty noise everywhere. I was on a deadline and so my solution in a pinch was to turn the visible light shape off (just the visible light shape though not the light itself) and replace with simple geometry placed over the light. I applied a simple A&D shader with glow turned on, with "illuminates the scene" turned off. I may have also turned off casts and receives shadows in the object properties. This way you avoid huge render times trying to clean up the noise.
Hope that helps
Meant to add, you then just add the glow aura in photoshop.
Hope that helps
whoa thanks buddy u saved my time on R&D i have one more question i get bright hot sopt around the light where in which i m unable to see the light source . i have to submit the output as fast as i can so pls help me out the light is on the wall not on the ceiling so i cant chop it of by changing cam location
