Solidrock and vray 2.0 problems
Sketchrender
Hi
I have been using SR (B09x) now for a white and it's not bad has helped, but i have issue with the interface after it has finished the render, it goes through this flickering back and forth, and will not let the image be saved.
I have written to the website about a month ago and have nothing.
Anybody a work around, i like to be able to tweek the image as i render with the vray Frame buffer, but the stand max does lot alow this.
Advise would be appreciated.
phil
Hi, I struggled with this too, until I found solution. It's actually super simple, problem is on Max's side.
Simply turn off "Progressive display" in Views on top shell. That's it. What this function does, is speed viewport navigation, but I haven't noticed much difference. You can allways just turn it off before render. This will solve the flickering. Funny huh ;- )
Another way is switching back from Nitrous to basic Direct3D, but I wouldn't advise for this, since Nitrous is actually much better. Only other problem I found using it is, problem with showing viewport environment. But oh well...
I'll give it a go thanks
phil
Well I did as you said and I am still having a problem.
it is as if the frame buffer is running out of memory.
On top of the frame buffer it say not responding.
And flicks back and forth and you can not save the image at all.
very , very frustratating after waiting a long time for an image to render for that to happen.
Hope somebody has come across this as it is pissin me off .
phil
Edited by philip kelly
