Camby1298 Posted October 9, 2011 Share Posted October 9, 2011 Anyone else using Max 2012, and their Reference Coordinate System is not displaying the different options? The Drop down box is blank...I would like this back...kinda importent. Link to comment Share on other sites More sharing options...
NeWAcEiN Posted October 10, 2011 Share Posted October 10, 2011 Anyone else using Max 2012, and their Reference Coordinate System is not displaying the different options? The Drop down box is blank...I would like this back...kinda importent. press Alt+right Click then one quad menu will appear here on Right hand side of the quad menu ull get RCS different options Link to comment Share on other sites More sharing options...
Camby1298 Posted October 10, 2011 Author Share Posted October 10, 2011 Thanks, this will work temporary, still gotta find out why my drop down menu isnt working, odd little bug Link to comment Share on other sites More sharing options...
NeWAcEiN Posted October 11, 2011 Share Posted October 11, 2011 Thanks, this will work temporary, still gotta find out why my drop down menu isnt working, odd little bug uninstall 3ds max 2012 completely del all files from appdata(only 3ds max 2012 files) as well as documents then fresh install and now it should b there !!!!! Link to comment Share on other sites More sharing options...
BrianKitts Posted October 11, 2011 Share Posted October 11, 2011 uninstall 3ds max 2012 completely del all files from appdata(only 3ds max 2012 files) as well as documents then fresh install and now it should b there !!!!! do you rebuild you computer everytime it crashes? This isn't a solution it's a last ditch effort. Link to comment Share on other sites More sharing options...
NeWAcEiN Posted October 12, 2011 Share Posted October 12, 2011 do you rebuild you computer everytime it crashes? This isn't a solution it's a last ditch effort. no i don't it is rare error in 3ds max so u ll have to do it that way some time MSI installer script doesn't install every thing or u can say some files were missing frm installer !!!!!!!!!!! so try to install 3ds max on other computer from old DVD and new DVD to old (Current) machine so ull figure it out the cause !!!!!!!!!!! Link to comment Share on other sites More sharing options...
NemesisGame Posted December 20, 2011 Share Posted December 20, 2011 You DON'T have to reinstall whole system to fix that bug. All you need to do is: 1. Go to Customize -> Customize user interface... 2. Tab "Toolbars" 3. Load 4. Choose "DefaultUI" Works for me. Link to comment Share on other sites More sharing options...
Camby1298 Posted December 20, 2011 Author Share Posted December 20, 2011 Such an intense thread for an easy fix. I had found the error, and by re-loading the defaultUI enabled the ref systems to display once again....(!!!!!!!!!!!!!!!!!) Link to comment Share on other sites More sharing options...
