yohozindagi1 Posted October 10, 2011 Share Posted October 10, 2011 Hello eveyone Here is this project i am working on for last two weeks, its an apartment here in Nepal. I rendered this image using 3ds Max 2011 x64 and Vray sp1 but i am unable to produce a nice realistic output with a mood. I used Vray Sun and Vray dome light with a very high quality HDri but as u see below output doesn't look good. i have tried so many ways even changing hdris, tried direct light source, adjusted vray camera etc. So plz any of you guys can provide me suggestions i will be very thankful to you. plz help me. Link to comment Share on other sites More sharing options...
aristocratic3d Posted October 10, 2011 Share Posted October 10, 2011 Only Realistic foliage will not make image look good. you need to work on materials. specially glass materials. and then land scaping. and then a nice POV. Link to comment Share on other sites More sharing options...
hockley91 Posted October 10, 2011 Share Posted October 10, 2011 I don't think it's as bad as you think it is. Some things that you may try is adding some texture to your exterior walls, adding a sky to the background and changing your lighting angle so you can maybe cast some shadows across the face of the building... I think the foliage looks fine. A bit blurry for some reason, but the scene is not that bad. Link to comment Share on other sites More sharing options...
selos69 Posted October 14, 2011 Share Posted October 14, 2011 If it were as easy as clicking a couple of buttons to make a render look realistic, none of us would have jobs. I would be looking at the composition of the image and the materials mainly to achieve a better result. Link to comment Share on other sites More sharing options...
hockley91 Posted October 14, 2011 Share Posted October 14, 2011 One thing I just noticed looking at it again is that there are NO reflections at all in the windows. That right there makes it look very unnatural...I still think some textures will help on it. Also, I think now that the grass looks like it's been shaved in spots...just make it a full grass texture...no bald spots for the $$$ shot. Link to comment Share on other sites More sharing options...
aristocratic3d Posted October 15, 2011 Share Posted October 15, 2011 Actually I appreciate to watch some tutorial online. there are plenty. Link to comment Share on other sites More sharing options...
maverick_gold Posted October 16, 2011 Share Posted October 16, 2011 you should visit cgtexture.com for some decals to place on your exterior walls Link to comment Share on other sites More sharing options...
nivvu Posted October 19, 2011 Share Posted October 19, 2011 Hi, Check on ur filter to catmull rom from area so avoid a crispy output image and i too see that therez no reflection and refraction in window glass, giving some opacity to window glass and showing some interior content wil make the over all image beautiful or atleast place realistic window curtains jpegs behind the window glass so it makes a good image and also add a good and clear sky with clouds with some birds in sky........all thebest.......... Link to comment Share on other sites More sharing options...
