NeWAcEiN Posted October 10, 2011 Share Posted October 10, 2011 3D's Max Network Render says scene save error when trying to submit the job plus how to add extra machines in NET render and if yes How many ??? Hope ill get fast replys!!!! Link to comment Share on other sites More sharing options...
datacrasher Posted October 10, 2011 Share Posted October 10, 2011 Soumitra you can use how many computers you want the min is one but if your going to net render on one computer then it may take longer so i would use two because you can work on one and let the other one render. Are you rendering as Jpegs or AVI? Link to comment Share on other sites More sharing options...
NeWAcEiN Posted October 11, 2011 Author Share Posted October 11, 2011 Soumitra you can use how many computers you want the min is one but if your going to net render on one computer then it may take longer so i would use two because you can work on one and let the other one render. Are you rendering as Jpegs or AVI? i m rendering tiff file. i just need to render 2 different views so i want them to get rendered one by one but when i add i get error cannot start 3ds max.exe and nothing happens Link to comment Share on other sites More sharing options...
datacrasher Posted October 11, 2011 Share Posted October 11, 2011 I am not sure why you are using the network render! why not just use the clone image on the render page to take two copies of different views? Link to comment Share on other sites More sharing options...
BrianKitts Posted October 11, 2011 Share Posted October 11, 2011 you'd be better suited to use the batch render utility not backburner, but on either route.... trial the help guide it will walk you through both. Link to comment Share on other sites More sharing options...
