pedroarq Posted October 12, 2011 Share Posted October 12, 2011 when i import archicad geometry i find many edges unwanted as i want to make some chamfers but can´t because the edges are not connected. anyone know a script to use in max 2012??? i work in archicad 15 Link to comment Share on other sites More sharing options...
BrianKitts Posted October 13, 2011 Share Posted October 13, 2011 no the archicad import wizard for max script hasn't been updated for 3 or 4 years. download and use the autoedge script as a start, then just be sure to weld the vertices of an object you're trying to chamfer and you shouldn't have any problems. Link to comment Share on other sites More sharing options...
pedroarq Posted October 13, 2011 Author Share Posted October 13, 2011 Thanks Brian I saw many posts from you about this problem. What method do you use recently to export to max? still export to autocad and then link to max???? the autoedge script don´t mess the geometry? do i need first convert to poly and then use that script? Link to comment Share on other sites More sharing options...
BrianKitts Posted October 13, 2011 Share Posted October 13, 2011 no i abandoned that route and went back to just doing .3ds files the script should work fine on an editable mesh. can you post a screen capture of the model so we can see what you're dealing with? Link to comment Share on other sites More sharing options...
pedroarq Posted October 13, 2011 Author Share Posted October 13, 2011 can you send me your email? it´s better don´t know how to post printscreen Link to comment Share on other sites More sharing options...
pedroarq Posted October 13, 2011 Author Share Posted October 13, 2011 (edited) i have already install autoedge selected script but doesn´t clean a simple mesh from archicad (( help please Edited October 13, 2011 by pedroarq Link to comment Share on other sites More sharing options...
greysheep5 Posted November 10, 2011 Share Posted November 10, 2011 (edited) hey guys! though marc hasn´t updated the archicad import wizard script for a few years, it still works fine... we use it everyday for our work. best regards, christoph. ----------------------------------------------------- cy_architecturevisualization. www.cy-architecture.com http://www.facebook.com/cyarchitecturevisualization ----------------------------------------------------- Edited November 10, 2011 by greysheep5 Link to comment Share on other sites More sharing options...
