Script for exploding all different elements into different object in one click
aristocratic3d
for this specifically you don't really need a script.
apply an edit mesh modifier, go to element or face sub-object mode, under the edit geometry area, you will find a button called "explode", the number on the right is the angle threshold for exploding the faces into different elements or objects. all you need to do is set that number to 180 (maximum tolerance), make sure the "objects radio button is checked and then click on "explode" works like a charm if indeed you just need to explode the elements in a mesh to objects.
Hope this helps.
