Tommy L Posted October 17, 2011 Share Posted October 17, 2011 I have a problem with an animated[ATTACH=CONFIG]45357[/ATTACH][ATTACH=CONFIG]45358[/ATTACH] boolean. Both objects are animated (Im trying to cheat a liquid surface by boolean removing the top side) White object has blue object subtracted. When the white object moves and rotates, I want the boolean operation to respect the movement. So, in the second image you can see the subtraction after 60 frames. The subtraction is moving round with the object. I need it to 'recalculate' every frame. Any ideas? Tom. Link to comment Share on other sites More sharing options...
Bruce Hart Posted October 18, 2011 Share Posted October 18, 2011 I think what you need to do is select the operand and animate it at the sub-object element level. I just tried it and it seems to work fine Link to comment Share on other sites More sharing options...
Tommy L Posted October 18, 2011 Author Share Posted October 18, 2011 Thanks Bruce. Ive bent my head around this. Any chance you could send me the scene? Ill PM you. Tom. Link to comment Share on other sites More sharing options...
Bruce Hart Posted October 18, 2011 Share Posted October 18, 2011 Hi Tom - just sent you the file Cheers Link to comment Share on other sites More sharing options...
