rendering problem
bobozd
hi,
i have strange problem when rendering same scene.
on resolution 1000x1000 px all rendering fine for 25min (lot of grass and plants)
and on resolution 2600x1950 same scene render 16 hours ???
is this ram because of bigger image or what? i cant figure out ???
intel i970 6core 12 threads
8GB ram
Make sure there are no standard materials in the scene, if there are you can use the vray scene converter.
If you are using displacement try unchecking view dependent.
Check the dynamic memory limit, if it is at the default 400mb crank it up, could be it's paging to the HD to much.
And last see if any of the materials you are using have a crazy subdivision setting, like 64 or something really high like that.
Good luck. :)
