Deetee Posted October 21, 2011 Share Posted October 21, 2011 im using 3dsmax design 2011 vray 2.0 this is how it goes.... frame 0-100 created VrayCamera at frame0 click "auto key" for animation purpose. pull VrayCamera at frame 100 to any other direction.... VrayCamera movement created from frame0-frame100 while "auto key" still on... i drag my timeline between frame 0-100 (didnt touch the VrayCamera anymore) nothing happens, except i see my camera moving in viewport. good... while "auto key" still on... get back to frame 100, animate the film gate (make it bigger/smaller doesnt matter) now here comes the problem... I drag my timeline between frame 0-100. it auto creates key frames for my camera at whichever point of the timeline i stop. It keep generating keyframes as long as i keep dragging the scroller at the timeline, regardless if im selecting the camera or not, it keep generating the keyframes. What's going on? :confused: It never happen like this before... It doesnt affect 3ds max default camera... I thought it may be my files corrupted, but even with new fresh 3ds max files, it still the same. Help~ Link to comment Share on other sites More sharing options...
Deetee Posted October 24, 2011 Author Share Posted October 24, 2011 No one ever has such problem??? anyone tried??? please? any problem? my problem is still exist.... 50 forumer read this yet no one having same issue with mine? Link to comment Share on other sites More sharing options...
hugoforget Posted February 6, 2012 Share Posted February 6, 2012 I have the exact same issue and it drives me nuts ; can't work in this context ... Did you find a solution so far ? I'm using max 2012 on Vray 2.10.01. Thx Link to comment Share on other sites More sharing options...
ryanguimond Posted February 6, 2012 Share Posted February 6, 2012 Im having the same issue. It happens when you click on the FOV checkbox. If you set any keys on this, it will set keys as you scroll throughout your timeline. The only way around this as Ive found up to this point is to not key the FOV. I copied and pasted my transform keys onto a new camera. Let us know if there is any other way around this. Driving me crazy. Link to comment Share on other sites More sharing options...
Deetee Posted February 9, 2012 Author Share Posted February 9, 2012 God.... I thought I was the only one that is facing such problem in this bloody world... I nvr key FOV. The only thing i keyed is the film gate... I thought this issue is hard to explain, so in my 1st post, i wrote how the problem was created... I thought it was just me alone having such issue as there are so many viewer in my topic yet none of them reply. did they even tried on how the problem created as mention in my 1st post? sigh.... anyway guys, im so sorry to say that i didn't find any solution here. I'm still hoping someone could give some solution here... As for any other way to work around this... What i did is manually turn on and off the autokey button. if there is anything involve film gate/fov animation, i will have to manually turn on and off autokey. when your autokey is off and you move the scroller along the timeline, it wont generate any keyframe. once you done with the camera, make sure save the scene or save the camera out as back up. just in case if you need to run autokey to animation any object in the scene, it will definitely generate more keyframes into the camera. and by that time you will need to merge the camera back in. Hope it helps. and im still waiting for someone to provide solution. Link to comment Share on other sites More sharing options...
robertcop Posted April 4, 2012 Share Posted April 4, 2012 Same problem. It must be a bug right? I've keyframed camera info for years without this happening ... and now, all of a sudden, I'm creating an FOV keyframe everytime I move the time slider. Link to comment Share on other sites More sharing options...
ryanguimond Posted April 5, 2012 Share Posted April 5, 2012 Still having an issue with this. Fortunately, you can open your curve editor, select the FOV and delete the keys. It will get rid of all the black keys on your timeline. Link to comment Share on other sites More sharing options...
Deetee Posted April 25, 2012 Author Share Posted April 25, 2012 ryanguimond said: Still having an issue with this. Fortunately, you can open your curve editor, select the FOV and delete the keys. It will get rid of all the black keys on your timeline. Yeah, apparently this is the only way to work around this bug. Somehow I'm wondering with this huge community of ArchViz artist in cgarchitect here, why it seems that just few of us having such problems??? This is so much annoying. I'm wondering is it bug due to vray2.0? coz last time I nvr get any issue with this before... Link to comment Share on other sites More sharing options...
cgwhiz Posted September 27, 2012 Share Posted September 27, 2012 I'm having similar issue using VRay v2.10.01 x64. Does anyone know if this is fixed in the latest version? Link to comment Share on other sites More sharing options...
