layer manager in autocad
anvaraziz
Are you saying that when you select an object in the drawing window that the correct layer does not show up in the layer spinner above the drawing window? ...or is the layer spinner gone altogether? If so, you may just have that toolbar turned off.
Otherwise, Edri is correct, if you are truly within the layer manager then you cannot select an object until you finish what you are doing in the layer manager and click OK.
I personally prefer the properties dialog box myself. You can view or change damn near anything from there.
Jeffrey K. Ries
