3dvizual Posted November 1, 2011 Share Posted November 1, 2011 (edited) How do I make small LED lights?. Like the attached image. Here is a reference image: Edited November 1, 2011 by 3dvizual Link to comment Share on other sites More sharing options...
3dvizual Posted November 1, 2011 Author Share Posted November 1, 2011 Not anyone who can contribute with some information, for solving this.? Link to comment Share on other sites More sharing options...
Dave Buckley Posted November 1, 2011 Share Posted November 1, 2011 self illuminated material ... with glare (done either in render or post) Link to comment Share on other sites More sharing options...
3dvizual Posted November 1, 2011 Author Share Posted November 1, 2011 Do you mean applying a vraylightmtl. on the object.? How do I give it glare in vray.? I am pretty new to vray, so there is still a lot to learn... :-) Link to comment Share on other sites More sharing options...
Dave Buckley Posted November 1, 2011 Share Posted November 1, 2011 yep, vraylightmaterial glare is easier in post, especially if you don't have vray 2. render out a self-illumination pass open the render in photoshop put the self-illum pass over the render put a gaussian blur on the self illum pass change the blending mode to screen reduce opacity to suit Link to comment Share on other sites More sharing options...
3dvizual Posted November 1, 2011 Author Share Posted November 1, 2011 OK. I use vray 2.0 But what you are saying, do you would always do this kind of job in in post... Link to comment Share on other sites More sharing options...
Dave Buckley Posted November 1, 2011 Share Posted November 1, 2011 Lens Effects in VRay 2 http://www.mattguetta.com/vraylenseffect-par-alfa-smyrna/ (you will need to translate this page) and apply the light material to the polygons that you want illuminated Whether I do it in post depends on whether its personal work/commercial work/how much time I have Link to comment Share on other sites More sharing options...
avvid Posted November 1, 2011 Share Posted November 1, 2011 Hi. Post may be the way to go, but if you want to try V-Ray 2's version: In the menu bar in 3ds Max: "Rendering" > "Effects..." > "Add..." select "VRay Lens Effects" > "OK". Make sure it's active and play with the settings. If you're not using Max, I'm sure it'll be something similar. There's a couple of workflow demonstrations on Youtube as well, but I've never had much success with it. Link to comment Share on other sites More sharing options...
3dvizual Posted November 1, 2011 Author Share Posted November 1, 2011 OK. Thanks. for your advice. I think post is the way to go.. :-) Thanks for your time. Link to comment Share on other sites More sharing options...
