NeWAcEiN Posted November 3, 2011 Share Posted November 3, 2011 hello guys i wanted to know which is the overall best Color mapping Filter in vray for exteriors though i have tried all of them pls give u r feed backs thanks!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
WAcky Posted November 4, 2011 Share Posted November 4, 2011 A quick search of google has yielded this: http://www.spot3d.com/vray/help/150SP1/examples_colormapping.htm This is a great reference but I personally use Reinhard. Im not going to get into LWF but if you have highlights that are blowing out you can bring down the bright multiplier to reduce these blowouts. The same can be said for the dark multiplier. You can adjust your blacks by adjusting this parameter. Try setting your light multiplier to .5, dark multiplier to 1 and gamma to 2.2 and go from there. Link to comment Share on other sites More sharing options...
danb4026 Posted November 16, 2011 Share Posted November 16, 2011 I also like reinhard. Unfotunately, I try to use LWF as much as possible and must use Linear because of that. Link to comment Share on other sites More sharing options...
