Ashleymatthews Posted November 8, 2011 Share Posted November 8, 2011 I Will like to know if anyone can help me with why these creases are coming up. I have all polys and its aligned well. I was trying to outline the button so I did an extrusion inside and then I pulled it out. Maybe I went about it the wrong way I just wanted to show an outline of the button. I hope that makes sense. The light switch is an example of what I was going for with this button. I think that's why creases are showing. If you have any ideas that may help, I will greatly appreciate your time Thanks Link to comment Share on other sites More sharing options...
luthias42 Posted November 8, 2011 Share Posted November 8, 2011 did you try adding a smooth mod to your mesh and making sure that all of the vert. are all on the same plane? Link to comment Share on other sites More sharing options...
datacrasher Posted November 8, 2011 Share Posted November 8, 2011 Ashley I would have created a box or 2d rectangle then extruded the rectangle and select the sides run about 4 connections through your main body of the switch. Once that was done then extruded the inner piece outwards for the switch. For the screws I would of created to 2d circles and then shapemerged so you can cut into the main switch body for the holes then put a couple of cylinders for the screws Link to comment Share on other sites More sharing options...
Ashleymatthews Posted November 8, 2011 Author Share Posted November 8, 2011 @ luthias42 no I didn't add a smooth mod because I used polygon smoothing groups and the verts are on the same plane. @ datacrasher thanks I forgot about the shape merge option, that works best Thanks guys:) Link to comment Share on other sites More sharing options...
AubreyM Posted November 9, 2011 Share Posted November 9, 2011 I would just use a box and the cut tool. Here is what I came up with, didn't take long to do. [ATTACH=CONFIG]45662[/ATTACH][ATTACH=CONFIG]45663[/ATTACH] Link to comment Share on other sites More sharing options...
Ashleymatthews Posted November 9, 2011 Author Share Posted November 9, 2011 Thanks Aubrey but how did you get those areas in the picture for the outline of the switch? Did you extrude in a certain amount of times? In your picture I pointed out exactly what i'm referring to Link to comment Share on other sites More sharing options...
AubreyM Posted November 9, 2011 Share Posted November 9, 2011 It's hard to tell from the screenshot I guess but yes they are just extruded. I'll send you the max file if you want to play with it. Link to comment Share on other sites More sharing options...
Ashleymatthews Posted November 9, 2011 Author Share Posted November 9, 2011 yes that will be great if you don't mind Link to comment Share on other sites More sharing options...
