danb4026 Posted November 10, 2011 Share Posted November 10, 2011 I cannot seem to figure out what the problem is. If I put a map directly into the viewport background via "files", the background shows up in my viewport, but if set it to "use environment background" it does not. Anyone have a similar issue? Using VrayHDRI for environment, max 2012 and vray 2.0 Link to comment Share on other sites More sharing options...
RyderSK Posted November 10, 2011 Share Posted November 10, 2011 I cannot seem to figure out what the problem is. If I put a map directly into the viewport background via "files", the background shows up in my viewport, but if set it to "use environment background" it does not. Anyone have a similar issue? Using VrayHDRI for environment, max 2012 and vray 2.0 Seems to be an issue with Nitrous driver. When you disable it, it works properly again, but then you loose the speed of new viewport. I don't know how to fix this one. Link to comment Share on other sites More sharing options...
